What the heck did this?
voidfinger
Hey guys, I sold my PI intake and heads and what not. I was taking the PI intake off the npi heads on my car and I noticed this before I put on my npi intake again.
The water jacket on the drivers side has the big chip in it... I don't know what could have caused it... its so smooth and has some spots look like something struck it below the chip... anyone know how this could happen?
[attachment deleted by admin]
9psi 98
That looks like a bad spot in the casting that let loose due to a quick temperature change. There really isn't anything in your cooling system that would strike it unless you hit that spot with a pry bar when removing the intake manifold before. It's just such a clean break that it actually looks like how arrow heads were made out of rocks a long time ago. I think more of an issue would be where that piece went, not what caused it because it's going to either block something or tear your water pump to shreads.
V
voidfinger
o well, I rather it get the water pump than having to pull the heads off... cheaper anyway...
9psi 98
That looks like a pretty big piece that came off. Hopefully it finds a low spot somewhere and lays there for the rest of your motor's life and causes no problems.
V
voidfinger
lol yikes :crybaby2: I don't know, wonder where it ended up though lol, it went down that hole i think b/c of the scratch or ding marks on the bottom sides of it.
9psi 98
I don't know man, but I am still sticking with the idea that there was a problem in the casting. You could'nt knock a chip off of your block with a chisel that clean if you wanted to.
V
voidfinger
I know lol, it has like 19X thousand miles so I'm like wow wtf you wait till now to do this lol
vermilion
maryland
tape off your intake ports. remove the water pump. empty your cooling system and use a water hose and flush the entire system. hopefully the metal flushes out. little work but maybe save some pocket change.
9psi 98
That, I can't answer for you. But, it will have to go through there eventually if it gets caught in the current somehow.
