What thread size are the exhaust manifold studs
Adam Vinnicombe
Hi all I have a 2001 Ford Mustang GT. I’m installing a new exhaust manifold/header and I thought the manifold studs where M8x1.25 but they are not. They do fit but they are loose does anyone know what size nuts I need?
Cheers
OLD H2S
Silver Spring Maryland
??? You are right at 8x 1.25 I use a product called Tight made by FelPro to lock them in because it is a thick gel and doesn't drip and run off.
Adfalenski
Pasquotank county, NC
I worked in a Chevrolet parts department for a while and have had a lot of experience with metric and standard fasteners. I recommend you try a 3/8”-16 bolt to check the fit. If it is too tight, try a 5/16” bolt. As an example, the GM metric engine blocks used 3/8”-16 exhaust manifold bolts but metric for the rest of the engine. 8mm = 5/16” and you said that your bolt fitted loosely.
Adam Vinnicombe
Adam Vinnicombe
The m8 x1.25 nut do wind up and torque up on the studs but they just don’t feel right, they can wobble a little on the threads before you torque them up.
Adam Vinnicombe
Adam Vinnicombe
Would they be UNC or UNF
