whats my offset?
x182dan
I have an 18x8.5in rim. Its on the front of my car and I found out its bent so I need a new one but they make them in two different offsets and I cannot find anything on the back of the rim to tell me what offset it is. The two options are +13 and +38. Which one do I have?
fixthedoor
Measure your rims to find out. More than likely it's +13, but measure the offset on the rims to be sure.
X
x182dan
to measure it I go from the hub to the back of the wheel right?
X
x182dan
ok I found ET: 34 on the back of my rim does it make sense that I have a 34 offset? Basically to find the offset I go from the middle of the rim to hub mounting point of the wheel?
fixthedoor
If you are trying to replace (1) rim -
A. you took the wrong measurement
B. manufacturer changed offsets. It's highly unlikely the manufacturer changed specs.
According to your first post you only have (2) options +13mm or +38mm (about an inch difference).
It sounds like you have the right idea. Google "wheel offset" to find more pictures and info.
X
x182dan
it turned out my choices were not 13 and 38 but 13 and 34 the guy who emailed me the offset options typed in 38 by accident
X
x182dan
my backs are +38, does all this seem about right? I probably could have left my quad shocks on but I couldn't even fit my pinky inbetween the tire and the quad shock. I am running 285/35/18 in the back
fixthedoor
Yeah that seems pretty tight. Recommended offset is +15mm to +25mm. I'm not sure what the recommended backspacing is. You can purchase wheel spacers to push the rims outward.
