which cam would be better?
slopony
well I found a good deal on a set of trick flow heads and a trick flow track heat intake. gonna swap it out from the stock heads and professional products intake. right now I have the steeda #19 cam. would this be good for my set up, or should I think about a different cam like TFS, comp, or maybe AFM? it's a 306 with all the bolt on's and a beefed up powerdyne supercharger. it's also an auto car.I'd really like to keep running my 1.7 roller rocker arms too. thanks
I think the one you have would probably work good but i could be wrong. i personally like custom grind cams from isky
slopony
well if it won't help out a whole bunch then I might just keep my steeda cam then.
