Which size injectors
Corndiddly
Collins, WI
Im going to be running TFS tw 170 heads, TFS stage one cam, Edelbrock upper and lower, and long tubes with 4 pipe. Will 24 lb injectors be big enough or will I need bigger? Also, whats the difference between the EV1 body and EV6 body?
whiplash473
Northern IL
if you're gonna buy them i'd just go with 30s but if you found a deal on a set of 24s then they'll be just fine
ram360
Your going to be running those 24's at 80% duty cycle with that h/c/i. Spend the extra few dollars and go w/ the 30's.
Corndiddly
Corndiddly
Collins, WI
I got a buddy with 24 lb injectors off his 4v I'm getting for cheap. So I would have to spend a good amount more.
Running that same setup now with the exception of a different intake/exhaust. Only part I found that needed upgrading after going to 24's was the fuel pump as it was starting to max out according to the dyno.
