Which wires are which on the dimmer switch?
DUALPOWERADDER
Searched with no lunck
Anyone have/ know which wires do which on on the actual dimmer conection plug?
Need switched power, constant ground and dimmer voltage output (for gauges)
Thanks
CC'S95GT
Hampton ,Ga.
do you have a haynes manual? there are wiring diagrams in the back. I'm not sure if it will be detailed enough for the HL/dimmer sw.
CanaryGT
Phoenix
Well Black is ground and Yellow is power. Red is your 12 volt acc line. Which deck did you buy cause if its Alpine, from my experience, hooking up the dimmer switch is pointless.
CanaryGT
Phoenix
Wow... I feel like a special little boy. I didnt read your post at all...
Pin Number Circuit Circuit Function B1 38
(BK/O) Power Supply to Battery B2 195
(T/W) Tail Lamp Switch Feed I 19
(LB/R) Instrument Panel Lamp Feed IGN ? Not Used R 14
(BR) Headlamp Switch to Tail Lamp and Side Marker Lamps H 15
(R/Y) Headlamp Dimmer Switch Feed DN ? Not Used D1 54
(LG/Y) Interior Lamp Switch Feed D2 706
(GY) Battery Saver Door Switch Feed
Diagrams in this link. http://www.fixya.com/cars/t2116060-86_mustang_head_light_switch_pin_out
DUALPOWERADDER
Thanks a ton. I had already gotten it figured out using a multimeter. However I was having trouble due to the battery kept dying ( less than a year old)
Looks like the alternator is toast.......... So either spend $179 now to drive the car for maybe a month, then start installing the eaton swap. Or I can start it now........
