scott5
If you have the same exact cars which would be cheaper to get into the mid 10s with while keeping it streetable a sn95 with 5.0 or a sn95 with a 2v mod motor?
scott5 said:No i am not talking about daily driver, I am talking about weekends and nice days and going to cruises. And can go to the pump and fill up and not get 9 mile to the gallon it will have power steering and ac. It will be power adder assisted. Maybe high tens or low elevens. the base block would be a 4.6 or 5.0.. My friend already did it with a 306 and a vortech ran a 10.89.. I would def probably add some cubes.
Mr. OAM said:With 11:1 compression it would not be a very fuel friendly car. You would have to buy 100 octane unleaded and that would be a little cost prohibitive for a car that is more than a weekend warrior. Might be able to get by with 97 if retarding the timing.
My point was that in a normally aspirated engine (4.6 or 347 stroker) the engine would have to be built for top end HP to get into the 10's and would not be very streetable in 25 and 35 mph zones. I am presuming he is talking about a daily driver or near daily driver.
The turbo can let you build an engine that is more streetable with power on demand. I also work with a guy that had a Cobra with a Kenne Bell supercharger on it. He showed me his dyno sheet of 597 HP and 609 lb. ft. of torque at the wheels. He put in a solid axle to take the power. This is another power on demand engine.
The other option is to add displacement. Go ahead and build a 408 Windsor or Cleveland stroker, drop in a 390, build a 400 (lots of articles to build killer 400's now and they are cheap) so that the engine doesn't need to be built to such an extreme so as to sacrifice streetability.
Steve
