PinkieT
Thanks for your input. End goal - improve on the stock NPI power without breaking the bank. Car is a cruiser, maybe autocross, but not a drag car.$600 for a set of PI heads? were they ported? Local pick a part place near me sells heads for like $50 each, a little more if its OHC with cams included.
As for the best combination, honestly you could go either way. PI swap is great to have the added compression, and can take a wider range of cams. NPI heads coil bind around .540", so in stock form they need lower lift cams. The heads can be modified, but few people do so. Another thing I want to do someday.
Honestly, if i had PI heads and intake sitting there already, I'd want to use them.
The only fly in that ointment is if you're doing all this in the car, in less than ideal conditions.
I've done swaps like this, and if I did it, id pull the engine and put it on a stand. Call me lazy but its much easier.
The cam/intake swap is more of a low buck simple thing to do. The headswap is more involved. Yes it nets a few HP, but I don't know what youre used to or what kind of a shop youd do this in.
Sent from my moto z3 using Tapatalk
edited because i am a bad proofreader lol
To clarify, around $600 is what I see Comp Cams and others aftermarket cam pairs go for new. I have half that in my brand new shiny unmolested Ford PI heads with the stock cams. I have a pick a part nearby where I can get a pair of used cams for under $100 but I am leery of putting boneyard cams in. I did the heads myself I would pull the motor. That ain't lazy in my book, it's working smart! Shop I would use locally is The Snake Pit https://www.tspspeedshop.com/. Heard lots of good things about them. Being a retiree with limited income, I am tempted to meet in the middle - I pull the motor, let them do the engine work, and put it back in myself. Either way, might as well replace the clutch while I'm in there, right?
