Will my blower be enough?
97stanger
Well, as some of you know I am in the process of building up my motor. I just ordered my forged internals, and just got my block back from being .20 bored and honed and whatnot. I will be running stage 3 heads/stage 3 cams/meth/bolt ons/8 rib/ SI Trim/Paxton front mount....just to give an idea. Now, through my built auto I want to be ATLEAST in the mid 500rwhp. I think that my weakest point will be my SI trim. Do you think it would still be possible to reach my goal using this blower? thanks
Lee12609
most definately...
i doubt it takes anymore than 12-15 PSI to get there either, but with the build motor you'll make a good bit LESS boost than previously yet make more power.
i think you'll be surprised.
duff daddy
I think its going to be close. A stock PI motor with on bolt ons and an SI trim made just over 4 @ the tire, you figured your cams, port and a little more boost, should result in close to 5 but Id say a T trim would get you there and youd be money
97stanger
97stanger
awesome. I just did some research and was happy to read about multiple guys in this power range through roughly 15-18psi through the SI trim.
97stanger
97stanger
I honestly cant justify in spending $800 more for a T trim, when the SI trim flows 50cfm less. I forgot to mention i will also be going 8 rib and running 10% od crank. My setup is with 18cc pistons which will put me roughly 9.5:1
Lee12609
with your heads/cams i still say you'll be pleasantly surprised when you see the numbers, so long as the tune is on point i see closer to 600 than 500, oh are we talking mustang dyno or dynojet. either way you should be happy.
97stanger
97stanger
my tuner is top notch, and it is dyno jet. i dont want to get carried away with dyno numbers, i just hope she performs good on the street
Lee12609
yep dyno is a tool, track is where it counts. hurry up and get some ET's......
97stanger
97stanger
haha its getting there. still lots of odds/ends....but i have the meat/potatoes all done so hopefully by end of summer/early fall
justinschmidt1
that thing is gonna be a monster dude.
With that much power through the stalled auto I would think you would be deep in the 10s assuming the car can hook
97stanger
97stanger
i pretty much have every suspension mod keeping it 4 link that i could. I would think if i could hook that i should see 10s, but you know how these cars are....ya never know. All in all, I want to eventually see 600's out of this thing. I doubt in the beginning I will see 600, but all it should take is some playing with the pulleys and i should be there.
97stanger
97stanger
thanks brotha! im trying. im definitely bringing her down to every show i can next spring/summer/fall including mustang week.
justinschmidt1
Well, with im at 385 rwhp and im pretty confident my car would do 11.50s with slicks.
I would sure hope with another 150-200 rwhp you can pull 10s lol
mikey94gt
Nice build. ill watch this one with interest, should be a fun car when you're done.
97stanger
97stanger
I'll just be running 93 octane with snow performance's stage 2 boost cooler kit which makes it about 116 octane. thanks guys for the props.
Lee12609
considered E85 or is it not readily available around there yet??? i know the meth plus pump gas will make more power but it seems like constantly worrying about a meth pump failing or line failing would be too much for me.
97stanger
97stanger
i have talked to a few race shops about e85 and they made it seem like it isnt an easy thing to come by here in south jersey. i have considered that, thanks for the opinion
Raz2752
