will supercharger work?
19blockhead72
Quick question fellows. My car is a 97 GT and I found a supercharger set up for a 99 to 04. Will it work on my car? Thanks.
Rob04Mach1
If we're talking bout a Centrifugal Supercharger for a 4.6 2V the Mounting Brackets are different
For Procharger for example
99-04 uses Bracket #AB018A-006
96-99 uses Bracket #3FDBB-002
19blockhead72
19blockhead72
That answers it. I guess I could get the bracket but it really wasn't that good of a deal to do that. I'll keep looking.
Rob04Mach1
It can all be converted but it depends what your getting and what you have to convert, that will tell you if it's worth it.
You can call ATI and tell them what you want to buy, and what you want to install it on, they can tell you exactly what you need and how much.
ATI ProCharger, Phone: (913) 338-2886
I once bought a used Procharger P1SC for a 04 4.6 4V and I put it on a 96 4.6 2V, but there was a lot I couldn't use. I got it at a killer price and it came with (2) MAF's, Fuel Pump, Injectors, Intercooler, bypass set up and all the piping for that, and a boat load of tubing and connectors. In my case it was worth it because I ended up finding a used Plate and then I used my Stock Lightning 90MM MAF, Stock Lighting 42lb Injectors, I sold the Cobra TB Pipe, Crossover, Inj's, (2) Maf's, and simply had to pick up some Bolts, Nuts, Belt, and a bunch of Rubber Fittings to make it all work.
It wasnt the nicest install in the world but I did it by myself one Sat and was driving it that night and the results were amazing.
RkYwN0I4RjdGQjAzQUYwRjExMDk6ODMzYTBmYWQ0MGFmMmY3Y2MyNTE1NzBkNTE5YjE5ZmI=
I just sold a perfect PROCHARGER used plate to someone on the forum for like $50.00 to help a Brother out but it was for 2004 4V so it woudnt work for you.
This is the current set up I have on my Mach 1, much cleaner install
ScottyDsntKnow
96-98 front covers are identical. 99 is a one off. 2000-2004 is its own thing. Just get the bracket you need for your year from ATI or Superchargersonline and roll or swap timing covers. You will also most likely have to convert to COPs but besides the the front accessories should be fine on what you have now. Like when you do a PI swap on a 96-98... you don't have to change front covers or anything it bolts right up.
I have a 2000 GT, I'm swapping to a 4V, using a 96-98 Cobra front cover on a 99 C headed Cobra engine and 96-98 4V brackets for the Novi 2000 that originally came with 2V brackets for a 2000-2004. It all bolts right up. I'd buy it if the price is right.
