Window problem
auto_x5.0
Alright, my passenger window will roll up and down if you help it, what is wrong? I was told it's the gears in the motor. Is that right, if so where can I buy the gears?
Look on the How-to section, I did a write up about this problem with our 94-95's.
You can get the gears at Autozone,Oreilly's or advance.
The part number is on the write up aswell. Good luck.
wytstang
Pickup ed those bushings today for 8.XX in the Help section.
Dang!! 8.xx
When I did the write up I paid less than 6.00 but still good.
wytstang
Still cheaper then a new/used motor. I should know I paid $25 for a used one for my pass side months ago. Now my driver needs help going up all the way.
Yeah, its cheaper fo sho that's the good thing about our shitty motor lol
wytstang
If you don't have a good pair for Snap ring pliers get some. I picked up some cheap ass ones at advance while there. Big mistake. I just spend an hour trying to get it to work on the small snap ring, finally got if off but I'm going to finish the job tomorrow with a quality plier. It literally could not fit in the hole, I had to use a small screw driver and the pliers to spread it open.
EDIT:
Took the POS Advance Auto retaining ring pliers back and took off to sears and pick upped this handy dandy RR pliers
00947411000
http://www.craftsman.com/shc/s/p_10155_12602_00947411000P?vName=Tools+%26+Equipment&cName=Hand+Tools&sName=Mechanic+Tools&keyword=retaining+ring+pliers
Worked perfect for the job and a huge difference in quality thats for darn sure.
Jerry santos
