Wires?
Insayne
Anyone have problems with ford racing 9mm wires? Just had an electronic stethescope under the hood and there was a ton of interference coming out of the wires. The stethoscope could pull interference 3 feet away from the dizzy. I have an msd coil but I don't think it bumps the signal enough to create this issue. They sound like they should be jumping between eachother but you can't see it. It's odd.
a clicking noise? I was taught that it meant you had a bad cable. Try and see if you can isolate it to one cable.
I
Insayne
well i was using an electronic stethoscope, so its clicking because it creates electrical interference. i tested it on a 90's chevy truck that has a 4.3 with modern hei and you couldn't get interference from the wires until the tip was roughly 1/16 of an inch from the wire itself. then i tested another vehicle. a 99-04 f150 4.2 DIS and i got interference at about 3/16 of an inch from the wires but no where else. both of those trucks have 7mm crap ass wires on them. my mustang literally has interference 3 feet from the plug wires!!! but there is no visible arcing.
justi88
Cochabamba, Bolivia
sorry for jacking the thread but i just installed my msd blaster coil and now i can here interference in my speakers :huh: what could be the cause to this?
DFG_magic
Kennesaw, GA
Do you still have the noise interference resistor hooked up that sits on the back of the coil bracket? Could be your issue.
I
Insayne
no its there. the distributor isnt oe. its a richporter oe replacement the oe almost seized.
Pure84GTT
they are mysteriously cheap, Ive always had a dis trust for them, yet never had any issues with them lol
I will eventually go to set of jacobs or msd ones, but for now the motorsport ones will do just fine.
justi88
Cochabamba, Bolivia
yes i still have and looks like its stilled hooked up... i just took the old one out and installed the msd and starting hearing that annoying sound in my speakers
I
Insayne
I think I'm going to get a mad set. Straight plug ends work with bbl equal length shorties right?
