MAF: round piece in the middle of the intake track with wires running into it.
remove it from the intake track and gently spray it with the MAF cleaner.
IAT: small "thumb-size" sensor in the top half of the intake plumbing with one wire running into it.
removie it from the intake track and gently spray it with the MAF cleaner on both sides.
Air Filter: inside the large "football-shaped" housing on the passenger side fender, or inside the fender if an aftermarket set-up is used.
Remove and replace paper filter. If using an aftermarket oiled filter, remove wash, let dry, re-oil, let dry, place back on car.
Throttle body: small metal housing located after the intake plumbing, but before the plenum. Has a sensor on it and also has the throttle cables attached to it.
Remove intake plumbing. Keep butterfly flap closed. Spray inside (with flap closed) with throttle-body cleaner. wipe with rag if desired.
If an aftermarket Throttle body and plenum are in use, open the butterfly flap and lightly spray the isnide as well, use a rag to wipe off excess Throttle body cleaner.
Plenum: Located after the throttle body and sits atop the intake manifold. Roughly the size of a box of checks.
Do not wash your OEM Plenum. If an aftermarket plenum is in use, see previous steps for cleaning an aftermarket throttle body.
Intake plumbing: The tubes running from the air filter to the throttle body.
Remove the sensors and remove the pipes from the vehicle. Inspect for damage and inspect the inside for motor oil. THe PCV system, on occation, allows oil to enter the intake plumbing. Clean out the tube with Throttle body cleaner and wipe it clean with a rag.
Battery terminals: Metal posts located on the top or sides of the battery.
Remove cables. Remove insulator cover. Remove felt washers. Wipe with rag. Use baking soda and water solution to remove corossion off terminals and ends of cables. Apply new felt washers. Apply petrolium jelly to the terminals and calbe ends. re-apply the insulator cover. Re-apply the cables.
Inspect all wiring for corrosion/breaks/damage. repair as needed.
IAC: located on the front of the plenum. small cylinder shaped unit.
Remove wires. remove two bolts. remove IAC. Clean with MAF cleaner. reapply unit to the car.
o2 sensors: located inside the exhaust pipes. 4 come stock. remove and inspect them. If you hear them "rattle" like a bad light-bulb, replace them. Inspect wiring for damage.
that will start you off...
