Yes, another Explorer Intake question
nolan62
Loganville, GA
Ok, 2 questions. I have been reading everything I can find. Haven't found an answer. Right know I will have to use a big spacer to get it to fit. But that would mean hood clearance isn't going to happen. If I can make some changes I can fit this with either no or a small spacer. So here is what I'm thinking and you guys tell me if I'm crazy. Thanks guys!
First, the black tube is for the PCV valve. It connects in 2 places. Do I really need both? Can I remove the one circled and plug the hole?
Second, I will not be using the EGR system. Can I trim off this part on the elbow if I find a way to plug the hole?
FivepointSlow
Enfield, CT, USA
Not sure on your first question but for the second question, yes you can trim that part of the intake off. I don't think it would cause any problems. All it's there for is to secure the EGR valve and you don't have that anymore..
Crapatalkin' on the iPhone 5.0
SLOW95GTS
I have that piece cut-off my intake and i still have egr. You can cut it if you have to. I also have the pcv port plugged with a fitting and just ran the hose from the pcv to the bottom the intake nipple.
nolan62
nolan62
Loganville, GA
Thanks, but it's not powercoat. It's Duplicolor's Metal Cast Paint. Really came out nicer than I thought. If I trim that part off the elbow I can just touch up the paint.
nolan62
nolan62
Loganville, GA
OK, I find out what the first picture is. I decided to stop by a Ford dealer on the way home and ask the guys in the shop. They told me that it is part of the internal EGR system. It's not used for my purpose. However, since it will clear the valve cover I can just leave it and plug into PCV into it and I'm done. Trim the elbow down and I can forget the spacer and any hood problems. Thanks for your input guys!
Rlee1773
