Yet another problem.
98BlackGT
North Brunswick NJ
I've been having this problem for a while but it would only happen once in a while. Today it happened on me 3 seperate occasions. The car would crank and not start. I would have to crank it for about 10 seconds about 3 or 4 times and it would just start. Not sure if this could be related to my hesitation problem I am having as well. Any ideas?!
This sounds like what happened to me last year.
Is the car getting fuel?
the5.ohh
Shaolin, NY
I've had this happen.. Try hitting the fuel pump reset button in your trunk on the left side. did it for me.
99GreenStang
It's either fuel or spark on this one . Check all your plugs to make sure you don't have a fouled plug
Check coil , distributor whatever
Make sure your wires aren't cross firing and aren't burnt or cut and are secure to the plugs .
Check for sufficient fuel flow and a steady one .
One of these I mentioned should take care of the problem .
God Bless you
senior001
