Kboss87
SOLD
Location: Sellersville, PA 18960 (local pick-up only - no shipping!)
Price: $750
Phone #: *removed*
Have an IRS assembly out of a 2003 Mustang Cobra. I was told it only had 50K miles on it when I purchased it. The wheel bearings and axles appear in good condition so I believe it to be true.
I have the complete cradle assembly, gear center section with upgraded Ford Racing rear differential cover, axles, rear eibach lowering springs, spindles, tie rods, and brakes. Goodies from Full Tilt Boogie Racing include Delrin isolated rear differential lowering mount and Aluminum Front Differential Supports (part numbers # FT 1200 and FT 1401)
The stock gears were removed and replaced with 3.73. The gears must be properly setup (set pinion depth, carrier shims, etc) before install use.
Items I can think of that you would need to install:
IRS shocks and IRS exhaust
ABS sensors if you have ABS and want to keep it functional
Sway bar end links are missing (these are $50 for a set from FTBR)
Price: $750
Phone #: *removed*
