331 head selection
BOS-94-003
The build:
331 Boss Block Short Block -
Machined Boss 302 Block
Scat 4340 Forged Steel Crank 3.250
Scat 4340 Forged Steel H Beam Rods
Probe SRS 2618 Forged Piston 14.2cc Inline
Perfect Circle Moly File Fit Rings
Clevite 77 Main Bearings
Clevite 77 Rod Bearings
Durabond Coated Cam Bearings
Fel Pro Rear Main Seal
Custom Ground HYD Roller Camshaft
Comp Cams Billet Timing Chain
Moroso 7qt Oil Pan
Moroso Oil Pump Pickup
Melling M-68 Oil Pump
Billet Oil Pump Shaft
Fel Pro 1 Piece Oil Pan Gasket
AFR 185cc heads or TFS Wedge Heads or Dart Pro 1
(customers choice)
Head Bolts
Head Gaskets
Comp Cams Lifters
Scorpion Racing 1.6 Rocker Arms
4130 Chromemoly .080 Wall 1 Piece Formed End Pushrods
The story:
For some reason I have always wanted AFR heads (not sure why because I have no expeirence with any aftermarket head). I ordered my motor with AFR heads but their supplier is out and awaiting shipment. Time is not an issue but they offered the other two heads at the same price and offered to cut the pistons for the TFS heads at no extra cost. The car will just be used as a weekend/sunny day cruiser. Transmission will be a TKO600 and a D1sc as a power adder. Is one head better than the other?
the trickflow head as more potential if your willing to have it ported. out of the box and just bolting them on i would probably go with the afr head
LAFENATU
Brand New AFR 190 head.
Have you seen them??
Pure insanity. Check them out. Better than all 3 heads you have listed.
They make the powe an AFR 205 head does.
The 190 flows 301cfm @ .550 lift
Ninety5_5Ohh
AFR's ftmfw!!!
I have the 205s on my 83 gt with a 347 and I couldnt be any happier. everything about the head is flawless.
BlkoutGT
MO
LAFENATU please post a link. I cannot find them on afr's site. Thanks.
LAFENATU
I have the article scanned on my computer at home. Ill try to remember to post it.
I posted it on a thread I made awhile back. see if yoyu can find it on the search here.
AFR 190
fastgtfairlane
really just depends on how much power you want to make with the combo. i would go with the 205s if it were me
LAFENATU
From Ed Curtis.
AFR 190cc Outlaw Small Block Ford Cylinder Head
190cc intake runner
12.5* intake valve
14.5* exhaust valve
301cfm at .550" lift
Yes it will clear your factory shortblock with a reasonable cam.
It was flowed on a 4.060" bore with a 1 3/4" pipe
Yes this is a rotated chamber design, not like TFS.
Yes you can use a regular rocker.
There are no usable heads available to the public yet.
We expect to be able to sell them by the first of the year, spring at the latest.
We will make larger versions and are on the fence about a 175cc version.
Stock exhaust port height.
Standard style intake manifold.
The part numbers might change for production reasons.
The solid roller versions will most likely option to a standard 7/16" stud and will definitely be 10 degree.
Yes the flow numbers are actually that good.
BlkoutGT
MO
Sweet, that sounds like a good option. I wonder what kind of price tag it will have
LAFENATU
BTW that was from the end of last year so they might be available. They are in the 2009 catalog.
