4.6 dohc rebuild
Phoenix0783
The motor in my '97 Cobra is getting a little tired so when I found a complete engine for $350 with "a rod knock" I bought it to rebuild
Already removed intake, valve covers, harnesses, and accessories
Making progress
Not bad
Still not bad
Good cross hatch still
Heads were a little oily but OK.
About 5 hours to get this far.
Fingers crossed
Doh! #2 rod bearing
#1 main bearing
#5 main bearing
Other half of #5 main bearing
#2 rod journal
That cranks toast! Good thing you knew! What did the engine come from and what year?
MustangChris
Aurora, CO
hm. looks fine to me. Just put it back together and use synthetic next time.
[/sarcasm]
KillNThrill24
Cleveland Ohio
I <3 4v
I hate tearing apart 4v. Takes all day. Sounds like you've found your problem tho. Nice work tearing down
D3VST8R96GT
Marble Fall, AZ
This just goes to show you can never have too much oil in a 4v...... the pumps are the greatest but they suck the sup dry pretty often.... the only cobra motor I disassembled that had great rod and main bearings and journals threw a rod and did some minor damage to a sleeve
Ive literally had arguments with known modular forum guys about how easy the pump can suck the pan dry at high rpms. Im glad to see others know this as well. The pan is efficient enough but between gravity return and windage catching the return the pump will dry suck.
D3VST8R96GT
Marble Fall, AZ
So we are kinda taking over your thread .... kinda seems pretty common lately.... I think [MENTION=14727]96blak54[/MENTION] is following me.... or I'm following him
Lets assume the heads are fine. The block rebuild is going to cost more than what another junkyard score will. Let this block sit and start looking for another shortblock, but be sure to hear the run, rev it up, etc..
stillridin
