5 speed swap questions...
68mustang5.0
alright, i just picked up the pedal assembly and the boot/console piece. I just need a quadrant, lower trans/body boot, cable, shifter, and clutch assembly.
For the lower boot assembly, i have a lower boot assembly from a T-5. Can I use that for the lower boot? i heard that the T-5 and T-45 are almost the same.
is the auto and manual trans mounts the same? the trans mount on my car is brand new, not more than a few months old....
Any tips/tricks, advisories i should know about? Might start on it this weekend.....install the pedals at least, know that one is gonna take a long while, gotta be a contortionist to get under that dash...lol
Thanks guys!
G
GREG@SN95
Guest
I'm not 100% sure... but...
I do think that the T5 stuff will work on the T45
and I believe that the the t45 cross member is different from the AOD...
68mustang5.0
I believe i have a 4R70W.....its a 98GT....hell i cant tell the difference between an AOD and a 4R70W...lol
G
GREG@SN95
Guest
I'm sorry... I forgot the 'E'... lol,
What you have is a 4R70W which is an improved AODE
There are two versions of the 4R70, one has a low first gear (the W designation) and the car version without.
The difference between the AOD and AODE is the AOD is only hydraulic operated, while the AODE is a combination of hydraulic and computer operated.
lol... kinda off topic, but there ya go
19mustang95
lower boot should be the same, not sure about the tranny mount though.
68mustang5.0
the lower boot i have has 4 bolt holes on each corner....does it bolt into the same corners the auto shifter bolt into?
96sohc
Automatic/Manual GTs have the same crossmembers, cobras were different.
You'll still need a different block plate.
Pull the driver's seat out, should make it alot easier to get under the dash.
