94 gt not running correctly
ckcm9410
I just put a 95 cobra intake on my car with injectors mass air flow and fuel pressure regulator the timing is correct and the car still does not run correctly. We checked the harmonic balencer it is fine....anyone have any ideas?
95-stang
Any other mods besides the intake? I assume you put in bigger injectors which aren't really needed unless you do have more mods.
330CubeGt
Why does the intake requite 24's? And if you went from 19# to 24# that could be your issue. But with lack of knowing exactaly what the cars doing its hard to pin point a problem.
Adam95GT
Pull the upper and put your 19's back on... If your not tuned your running rich as hell.
extreme_21
Mtl, Canada
2nd that..but also you said the maf was upgraded to the cobra, put back the 19's and the original maf. The cobra had a different tune and cam along with the intake which resulted in a slight power lift. If you don't have anything else besides the intake, the 24's will run you rich unless tuned
Adam95GT
There is no difference in the cobra and gt Maf the difference is in the tune.... t4mo vs j4j1
330CubeGt
I agree i have a friend that went with a short runner intake on his cobra and its tuned for 24# and he slapped 42# on there and it runs like crap, runs rich and falls on its face around 4k rpm...
