94 vert window problem
matholland
I have a 94 vert...the windows in the back that roll down...well my drive side one, if you roll it all the way down and try to roll it back up it will click like its off track or something....If i take a pair of pliers and grab it and pull it up like and inch its fine..also if I just roll it down and leave it about 1 inch before its completely rolled down its fine...i guess my question is, is it the motor or what?
CC'S95GT
Hampton ,Ga.
Sounds like the regulator gear is stripped at the bottom.
You'll need to take the interior panel off to be sure though
matholland
Alright, i saw that tut, but it didnt say how to do it for a rear window...how do you get too it?
CC'S95GT
Hampton ,Ga.
Not that i know of.
To release the bottom,
Lift the front edge of the cushion,
There should be a button,
Push it in using a screwdriver,
Lift up on the bottom,
Repeat on the other side.
Seat bottom will pull right out once the 2 front locks are loose.
I don't know about the vert seat back.
matholland
its the same for the vert, ive took the sear out before...is there just a screw or 2 for that pannel, then self explanitory or what
