95 5.0 347 Stroker Overheating help??????
Zackqb2
OK I recently put a 347 stroker in my 95 the other day I was going up a hill and it began overheating. I have changed the t-stat wasn't that changed the water pump.....negative, and today I've changed the radiator and its still gets hot very fast......What could be the issue please HELP!!!!!!!!!!!!
98snakehorse
Southeast, IA
Did you burp the system correctly wihen you put the new radiator in? Did you install the thermostat in the right way?
Z
Zackqb2
I just pulled the t stat and tested it, it works fine. The stat should run side to side right and how do you burp the system
98snakehorse
Southeast, IA
To burp the system you leave the radiator cap off while you let the car warm up, this will slowy get all of the air bubbles out of the system. Any air pockets along the line will cause overheating.
det_riot
Dearborn
Idk what you're trying to say but the side with the spring should be facing the motor.
jack the front end of the car up and let it warm up with the radiator cap off. Unless there is a "higher" opening available on the car. Also, do this with the heater on full blast.
Z
Zackqb2
Yea I have a new cap, I'm about to go out and try to burp the system!!
squeeze dem big black hoses with both hands... be firm. you wont hurt 'em.... go up and down as you squeeze... just try and get that fluid flowin...
Mrstangerbanger
CHICO , California, United States
I would pull your CCRM out of the car and check to see if you burnt the unit up .. IF you wire your fan to run on a switch its very hard on the ground in the unit and it will burn it up ( only if you wiring the fan to the 15th wire in the unit) Its a ground.. Also make sure you have 2 speeds .. GO ahead and unplug the Coolant temp sensor and see if the fan kicks on high speed with the car running .. Then if the fans are works properly then I would check the bottom radiator hose and make sure it has a spring inside it . Flush radiator and check therm and you should have fix it .. Well in less its your waterpump .. Also check the fuse between the fan and fan wiring plug if your car has one .. Some do some dont
ivan12
This ^^^. It's very common that you fill up the radiator and it will come back out(hence the burp). Keep topping it off until it no longer does it. A lot of people just top off the radiator after some work turn it on and go, this leaves air in the system and the air and water become boiling steam.
det_riot
Dearborn
It make the burping process easier, if you're replacing your thermostat, drill a 1/8th hole in the tstat so air can escape. make sure when you install it, the hole is on top.
Z
Zackqb2
Water pump radiator t stat is all new I have the fan wired up to a toggle switch
Z
Zackqb2
I think I may have fixed it by burping it I let it run and idle for almost 10 mins the temp hand ran in normal operating zone......I'm gonna let it cool down and then take it for a spin to see if it's cleared up!!
det_riot
Dearborn
good to hear! did you notice a lot of air bubbles coming out when you were squeezing the hoses? If so, air in your lines was probably your culprit
RichV
CO
In addition to the burping, did you add a good big radiator? Or just a new stocker?
The stock radiator is crap. It wouldn't even hold temperature close on a race track. It did fine putting around town, but you get on the throttle for a period of time, my 94 was heating up. 250+, I got a little nervous with those temps. 230 is relatively normal at a road course when you're in high RPM on a hot day for 30min straight. But yea, put in a ZAP big 3 core aluminum, I was running 200 without issue.
