95 GTS midpipe
skohle
I want to install a off road midpipe on my 95 gts, everything else is stock. The thing that worries me is that once i do this i will be getting a check engine light or something of that nature. is there a way to get rid of this, do i need mil eliminators (if so were would i buy them, only can find them for 96 and up) and what about the smog pump hose connection. is there any negative affects for the car ( like check engine light) that will arise if it is not connected.
FirebirdTN
You don't need eliminators on the 94/5s. Our cars only have 2 oxygen sensors and they are located PRE cats unlike the 96 and up, so all you have to do is pick whichever ORH/X you want, bolt it up, and be happy.
-Alan
PS. I installed a BBK OR/H on mine and it had the connection for the smog pump. I don't know if all of them do or not, but the BBK H does.
if you dont have emissions just weld or bent the egr pipe and dont worry about the check engine light
it wont come on.
skohle
wow that was a fast response thanks guys.
so just to be clear
1. i only have 2 o2 sensors (pre-cat) so i won't get a check engine light there.
2. the smog pump hose not being connected also won't throw a check engine light?
1.- No
2.-No
id reccomend you to replace the O2 sensors if your car has more than 100k miles.
Z28This
javi said:
1.- No
2.-No
Yes, replace the O2 sensors! I had 172K on mine and it ran like a dream until i installed an off road h-pipe from Jegs. I must have jared something loose in them cause it ran like crap until i replaced the O2 sensors.
skohle
thanks for the heads up, ill watch for that problem.
I'd like to think i shouldn't have a problem, i only have 80 000 miles on her.
skohle
For my smog pump, ive been reading that i should just delete the smog pump(its winter now so maybe in summer) or cap off the hose. although i also read that if i cap it off people are having problems with the pump failing. so what if i don't cap it off and just let it pump outside air and just rig the hose up so it doesn't hit anything, would that cause any problems?
blackpony
id remove all the lines for the smog pump and plug the holes in the back of the heads... you will need a shorter belt to route around the pump and enjoy the new found space under the hood and the xtra power... my .02
Paul
You don't really get any extra power from removing the smog pump. The drag on the motor is negligible.
blkmcnasty
Illinois
Paul i must say that you have impressed me with your vast knowledge but this is one point i beg to differ. I know it may have been more from the a\c delete but when i did the smog and a\c delete, it really woke my car up with noticable gains. P.S. i have the summit delete kits for my 95 gt
I'd say you'd get more from removing the smog than the a/c, when the a/c is off it just spins freely. one thing you should know about Paul though is he'll never suggest removing your smog or especially EGR :tongue3: Not to suck his dick or anything though but he does know a lot.
blkmcnasty
Illinois
OnyxCobra said:
I'd say you'd get more from removing the smog than the a/c, when the a/c is off it just spins freely. one thing you should know about Paul though is he'll never suggest removing your smog or especially EGR :tongue3: Not to suck his stick or anything though but he does know a lot.
Hey i have nothin but respect for everyone on here. I just didnt want the op to get the wrong ideas about smog delete.
I would like to see the difference of the egr and ac delete graphically talking.
its worthless.
Dysfunction
Keep in mind that when you put the midpipe on and plug the smog pipe, you will destroy the smog pump.. And if you don't plug that pipe it will sound like you have a built in duck call. Get a shorter belt while you're at it and go ahead and bypass the smog pump. This is something i learned the hard way.
I just bypassed my smog pump this week. I have no noticeable gains except a new exhaust leak.
I figured it's the tube from the H pipe.
Paul
So what you're telling me is that based on your highly calibrated "feel" - the car really "woke up" and had "noticeable gains?"
While that's swell for you, a dyno would tell you different.
Paul.
