96blak54 Buddies 2001 F150 build
96blak54
96blak54
Staff member
Lawrenceburg Kentucky
Truck has a procharged 5.4l 4v and turbo 350 transmission. All built, no money spared. Dyno'd 650rwhp before the charger 8rib belt snaps. He has contemplated sawpping to a twin turbo setup, but time and effort sways his desires.
Here lately, his son figured out a big brake upgrade for his acura tlx and it got my buddy thinking about the brakes on his f150. They very subpar! 12inch diameter rotor, single piston calipers.....very sad for such a machine.
He pitched the idea of upgrading the f150 front brakes and we both got to work researching.
What we came up with (tons of online researching, number/dimensioning) was 2016 mustang gt350 rotors that are 15.5inch diameter ($125ea left/right specific) and 2021 Mustang gt350r 6 piston Brembo calipers($240ea)
96blak54
96blak54
Staff member
First we have to make one of his stock rotors into a spindle that will allow the gt350 rotors to slip on
Cut the rotor portion off
Now with the rotor portion gone, we moved forward with extra modifications to this spindle to accept the ft350 rotor. Most of the modifications were clearancing of the gt350 rotor castings that would interfere with a flush bolt together.
96blak54
96blak54
Staff member
I didnt get pictures of the rotor machining. Sadly i didnt think about it. Anyhow, the hub bore had to be bored bigger to slip over the bearing hubs and a new 5x135mm lug pattern to slip over the lugs.
96blak54
96blak54
Staff member
Making all this work together has turned out relatively easy. Asides from the machine work, the parts needed to be made were very simplistic. The desire was to keep the rotor as close inset stock as possible. That was achieved and we actually gain an 8th of an inch inset. The only downfall with fitment is the wheels. There is no diameter problems, the wheels are 20's, but there is interference between the wheels backside and caliper. Now that there is a massive chunk of caliper on the rotor outside between the rotor and wheel, a spacer will be needed. Nothing a 3/4" wheel spacer wont fix. Not desired, but necessary. Probably will need to space the rears as well. Initially, the wheels were ordered to their offset so that an air ride system could lay the truck out and the wheels could tuck. We added washers, figuring out the spacer needed and as luck would have it, the wheels still tuck under the fenders.
96blak54
96blak54
Staff member
The latest update
My guy had to order another set of spacers to clear the new MUCH MUCH bigger calipers and he had to swap the inner wheel valve stems to a short version. The spacers took 15weeks to receive due to manufacturer issues when guaranteed a 6week turnaround that turned into a drama story.
The axles had to be pulled out and wheel studs changed. The old spacers/adapters require specific length and the new spacers require longer specific length. No biggy, just more work, but that gave him the opportunity to update fluids and check seals............on a truck that rarely drives 100 miles a year.
He took the truck on its maiden voyage and the brake upgrade was a success! He reported that he was not easy on the brake pedal either. Driving the truck hard and braking hard to get some heat into the calipers and when he felt confident that the calipers should be hot, they were cool to the touch. This truck is by no means any track contender of any sort. Just a garage model to build and play with.
Before with the stock brakes, stock brake booster and supercharger, hard braking was an issue after getting into the boost due to loss of vacuum. The bigger brakes has helped stopping power and now he is looking at supplemental vacuum assist for the booster. He has mentioned a few options like vacuum booster delete, hydraboost, and vacuum pumps. Ill report back with his solution.
Just seeing the truck with the monster rotors and calipers has improved the eye candy visuals.
He just order another round of the same brake upgrade parts for his '98 Expedition.
qzxo_oxzp
