9838stang
My nitto nt555 zr tires?.... Lol. I only got these for the rear. My fronts are in pretty good shape yet.
If you got em for the rear why did you get four? Planning on blowing through the first set that quick lol?
Tha trap house.
So did the 99 pillars give the car a different look?
Congrats on the engagement!
Update.
I took the clock spring out and replaced it with the one i picked up from the yard. plugged everything back in and was still getting the airbag code34.
Damn!
I figured the clock spring had gotten wet while in the yard since the passenger door was hanging off the donor car. So went back to another yard and found 4 other cars. 2 of them still had the windows and doors on them. so no real moisture had gotten on the inside. I picked up 2 more clock springs and found one of the air bags i had laying around from my 2000 gt donor car.
Went home and traced the wires and found no issues with the wiring that i could see. I replaced the clock spring i recently installed, with one i just picked up from the yard. Again still coming up with code 34.
Now 94-98 cars had a difference airbag connector than the 99-04 cars, both passenger and driver. My buddy recently found me a site that shared what another guy had done while swapping his new edge components into his car. One of which was with the airbags and only the passenger side needed to me modifiy with an inline resistor to trick the cars computer to thing there is enough resistance inline. the driver side bag and passenger side bag then needed to have the 99-04 new edge airbag connectors pinned onto the 94-98 bags. ( only needed if you want to keep the 94-98 colors in the car)
So after thinking of all the possibilities, I then focused on the airbag. I plugged the 2000 air bag in... lol well the light stayed off.... ugh
So my tan bag went bad. I then did the unthinkable and took the airbags apart and swapped the airbag brains from the 2000 bag into the 1998 bag. and!!!!
taaaadaaaaaa it works
next... door locks lol to be continued
Was this only an issue with the passenger air bag? Did the drivers bag plug and play? If so Ill buy a 99+ bag and do what you did. I'm going to run into the same problem with my doors and air bags on my 03 Cobra wiring swap. I want the black bags for the 97 interior. Ill stay tuned because if you've already done it it will save me a lot of time so thank you for that
I feel bad for you front plate state guys.
