AFPR, EGR, and Vacuum lines
Matts50
I will try to make this coherent, but I am looking for some close-up pictures of everyone's AFPR and nearby vacuum lines.
I have a TFS Street Heat Intake with an elbow that has 2 small vacuum ports. I have a red vacuum line and green vacuum line, both, with black boots, that I have plugged into those 2 small vacuum ports.
Now, the AFPR rubber line is hooked into the vacuum port of the EGR. This doesn't make sense to me!
Am I wrong or should I connect one of the vacuum boots to the EGR and the AFPR to the intake elbow?
Hope this makes sense!
Thanks,
Matt
Matts50
11 views.....I didn't think it was a difficult question. Did I not word it correctly? I'm looking for some close-up pics of the area where your AFPR is so i can see if I have my vacuum lines routed properly.
Thanks!
Farr94gt
I had a similar problem, the green line goes to the EGR and the red plugs into the back of the upper intake along with the rubber hose
the green does go to EGR but the red one should go to the 3 hose vac tree at the intake elbow, green line should be one of them, one should be a big hose coming from the drivers side and the other small one should go tot he FPR.
