Aftermarket Gauge setup pics
evil9t5
On my old 95 i had the a pillar gauge pod installed and grew bored of it, now im looking for other ideas on where to install aftermarket gauges. Any pics would be great.
VT_svt
Saleen setup where the digi clock is looks really clean, easy to read too, same with the double gauge set up left and right of the stock dash cluster
(minus steering column gauge and a pillar)
:eek:ccasion14:
E
evil9t5
VT_svt said:
Saleen setup where the digi clock is, looks really clean, easy to read too, same with the double gauge set up left and right of the stock dash cluster
That looks nice man, where did you purchase the column gauge pod?
:eek:ccasion14:
BLCKSTNG96
Here's mine,Autometer c2 gauges,AEM wideband,Autometer cluster bezel and clock bezel,upr gauge rings and reverse glow cluster gauges which I plan to change.
VT_svt
Best of both right there
never been a fan of the clock pods with as far as they stick out. Looks like they sacrificed one of mickeys ears to design it IMO. I like the ones that sit in the gauge bezel and plan on adding mine there by molding them into it myself.
E
evil9t5
Thanks for the pics everybody Im set on installing the steering column gauge pod. It looks best IMO, and VT_svt thanks for the links man. Any more pics would be great.
GRN95DTOP
East Texas
I have the clock pod waiting to be installed. Im putting trans temp and water temp in it. I really like the cluster with 2 gauges in it but hear the quality sucks.
BLCKSTNG96
Quality is ok,it takes some adjusting and some gauges don't fit depth wise.I couldn't get it to sit flush without my c2 mechanical boost hitting the cluster so I had to move it to the clock pod.
blkmcnasty
Illinois
Let me tell you right now that the column pod fits like sh*t. I had to use a heat gun to get it to calm down and fit snugly. Then for a couple months after install, it would rub on the steering wheel when i would turn the wheel. But now that its been on for a while, its a perfect location IMO. The wires were very easy to run along the steering shaft but since the pod fits over the stock column cover, you have to drill a hole to run the wires through. I thinks that all.
CC'S95GT
Hampton ,Ga.
DALAMAR relocated the hvac controls to the lower mail box then placed 3 guages where the hvac knobs used to be. looks really sharp.
ProKiller
PA
my old setup:
newer setup switched to the cluster pod and C2s:
i have since reused my clock pod and put the wideband in there. but i don't have any pics of that at the moment
ivan12
Anyone have or seen this holder in person? I'm kind of on the fence still
