Does anyone know if adding one of theses to a sn95 will cause emergency brake cable problems and does it need a safety loop?
It could if the driveshaft is rubbing on the cable. It's a good idea to check on it once the installation is done. Is a driveshaft safety loop needed at your level? Depends on how you use the car (drag racing, slicks, etc.) but if you are going to take the plunge the driveshaft safety loop from Stifflers is a nice piece: http://buystifflers.com/driveshaftsafetyloop79-98mustang-1.aspxDoes anyone know if adding one of theses to a sn95 will cause emergency brake cable problems and does it need a safety loop?
Are you drag racing the car, using slicks, and running 11’s?
You probably don't need a safety loop.
Sent from my CyanMobileX Evo 4G
