Burninriverdiver
- Joined
- Jan 1, 2014
- Messages
- 2,770
- Reaction score
- 234
Nice work, glad you were able to fire it up! I didn't think that harness would be too much trouble for you.
So got the wires all soldered up today. But car won't run even after the tune dicked with it all day sat and got nothing checked the fuel pressure it was good finally checked compression. drivers side is fine pass side has little to non. Valves were hitting before the motor went in re adjusted the Intake cam and there were good. Hoping it didn't bend any valves when turning it over by hand gonna take it back apart this week and pull the followers and check compression and see where were atSo update please, and nicely done
Sent from my SAMSUNG-SM-G890A using Tapatalk
Yea gonna bleed them down today at work with the vice. I'm hoping it fixes it too I want my dam car running againI thought it was a pain to bleed down the lash adjusters on my 2v, I don't envy the double work you have to do! I used a c clamp with thick rubber tied to the ends; a vice would be much easier if you have one (if not it's a good excuse to get one). Hopefully that solves your issue with the compression
