DFG_magic
Tackled the PI intake swap yesterday. Removed the Dorman intake that the previous owner installed. Here are a few pics through the journey. I'll fill the system up with coolant and change the plugs later today.
Started with this:
A few of the parts removed. BBK 78mm throttle intake, underdrive water pump pulley, etc..
Coolant draining:
Water pump out:
Here's the nipple I pulled out of my 98'. This is the 3rd or 4th time I've seen a 98' with the correct PI nipple already in the block:
Nipple installed:
Used a 3/8 extension and a random socket with a hammer to tap the new nipple into the block. Worked like butter:
Water pump and PI coolant tube installed:
Fast forward to this; PI intake, FRPP 24lb injectors, new sensors in the water crossover, 3 ply silicone hoses:
Started with this:
Coolant draining:
Water pump out:
Nipple installed:
