Here's what i posted on Steeda's own forum:
The 95 mustang has been handling badly for the last month or so, but have been using my trans am so not a problem, decided to lift it up yesterday to see why, BOTH front Steeda Sports springs had snapped on the lowest coil nearest the lower front suspension arm. Literally a coil each side had broke, one a while ago, the other recently. part number is 167559 for the fronts and the rears which are perfect are 167504. I'm assuming i was supplied with the correct springs as these part numbers seem unavailable?
I used Eibach pro shocks front and rear, Ford racing castor\camber plates, and a bumpsteer kit.
Any ideas why this might happen?
Reply From SteedaGus sales manager:
Neither one of those spring numbers corresponds to a Steeda spring. At least none that have been produced in the last 10 to 11 years or so. If they are older than that I dont have any info to properly identify them. If they are not older than that then they are not Steeda springs.
As far as springs failing, that is possible if they are very old. Even stock springs can fail with age. Especially if the car is a northern car where enviromental exposure takes its toll over the years. If they are fairly new springs then a failure without some kind of outside influence, like an accident or other damaging impact is extremely unlikely.
Back to me:
Thanks for the quick reply, the springs are powder coated blue with STEEDA and those numbers above on them , i have the invoice from California Mustang dated 06\06\06, and it says:
88L039 STEEDA SPORTS SPRING SETS
1979-2004 V8 1984-2004 V6 price $229.95
Although i bought them all that time ago the car has only done about 5k on them, from what you say it looks like California Mustang have sold me counterfeit goods?
And if they are counterfeit why did'nt someone do a better job and use correct part numbers?
Obviously if they are inferior quality this might explain the breakages.
Sorry if this a long read but had no further replies, anyone got any ideas on why both have broke?
Back to me:
