Build my motor.
5.Woahhh
Lets keep this simple. By the end of summer I'll have 3k+-. I'm very indecisive and always found this concept interesting. alittle stats on my car.
96 GT 135k on it. Other then that the motor is stock.
Stock Trans.
Steeda CAI
BBK O/R H-Pipe
Flowmaster CB
Steeda Race Springs
Tokico 5-Way adjustable shocks and struts.
Pro-5.0
Steeda adjustable rear sway bar.
I'm open to all motor options, within reason. I'm just looking for some different directions that I could go in.
greenscobie86
The Big Apple
Maybe PI swap and some gears... Do it cheaply and you'll have a couple of grand left after...
Save that leftover dough for later... these days you never know when you're gonna need it...
duff daddy
If you want simple stuff you can do a pi MANIFOLD only, trickflow plenum, if you want you can try under drive pullies (split 50 50 on opinions) and there are a few other small mods you can do...but not a whole lot
5.Woahhh
javi said:
e-building a motor has never been successful
I know. I've never built motor so I am looking for ideas. But specifics(brands ect).Different combos and what not. I already figured the PI swap would be first.
97stanger
stage 2 or 3 PI heads, PI manifold, CMS cams, vortech, bolt ons....will keep you happy for a while
5.Woahhh
At what point will I need internals/fuel pump/ injectors/ ect?
97stanger
it really depends on how much you crank the blower up. anything more than 400-425rwhp i would go forged internals. You will definately need a 255lph intank before 400rwhp, atleast 42# injectors, and atleast a 90mm LMAF before 400rwhp as well. Anything more than that when you are building it up will need to be upgraded even more. I basically maxed my stock shortblock out with my vortech, now while I am building the motor up I have to upgrade everything that was already upgraded.
NXcoupe
Cobra forged steel crank, Teksid block, Probe I beam rods and forged pistons, .020 bore and hone with a torqueplate, top it off with a set of PI heads with a fresh valve job, and a stocker intake. viola! will take a lickin and keep on tickin.
