Re: General Consensus on Pro Products 75mm T/B
i have a stack racing 75 tb and it has two different whistles. i like it though. its an easy install, the tps does have two bolts and the bottom one is a little bit harder to get to, but dont leave it loose. wot will make it move and throw off your tps settings. put it together leaving the set screws a little loose and set your voltage to .98 with the middle wire, take the whole tb back being careful not to move the tps. take the tps off and tighten the upper and lower screws. put it back together and recheck your voltage. if it has moved just loosen the top one and adjust, it should be enough to line it out. a tb is a tb, its just a peice of pipe with a butterfly valve. not to much to screw up there!
