Buying a new CCRM
v8powerv8jim
U.K.
Hey guys,where can i get a new CCRM for my 94 GT?..fan works on both speeds when i wired direct to battery,but will not come on during normal driving.
Will do the manual switch until i get a replacement CCRM,as i would like it working like Ford intended.
Thanks
Does the temp sensor work? there are 2.
Does the hi speed fan come on when the a/c is turned on?
When you pull codes, one of the first things you'll hear is some relays clicking then you'll hear the low speed fan for couple seconds followed by the hi speed fan.
I'm just making sure not spending money needlessly.
v8powerv8jim
v8powerv8jim
U.K.
Sensor for gauge is working,pulled plug from sensor in heater tube & fan didnt kick in...i've not got A/C any more.
I forgot about trying my code reader to check for the fan...will try that.
Thank you.
v8powerv8jim
v8powerv8jim
U.K.
Well got hold of a code reader today,during the KOEO test the fan does not run on either speed but fuel pump primes ok.
I do hear relays clicking at the very start of the test..also got code 118,ECT sensor circuit above maximum voltage/ -40°F indicated. Not sure if its coincidence but i recently done a turbo conversion on the car and i relocated the CCRM,after this the fuel pumps would not prime until i tapped into the ground cable leading to the CCRM, & added another to it.
It's wierd that the FP would prime but the fan relays won't kick on.
Since the FP relay does work, that means the ground is making contact. Sooo the fan relays must be bad. right?
v8powerv8jim
v8powerv8jim
U.K.
That's my guess..i tried grounding out pin 17 and still nothing.
