I have a 95 gt with some holley systemax heads, 95 cobra intake, and a tfs1 cam. I was wondering if anyone knew enough about cams to help me deciding if i should switch the cam out for the original holley kit cam (lunati) or keep the trick flow stage one.
here are the specs:
trick flow
Part Number: TFS-51402000
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Lunati
Duration at 050 inch Lift: 218 int./222 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 280
Intake Valve Lift with Factory Rocker Arm Ratio: 0.509 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.509 in.
Lobe Separation (degrees): 107
here are the specs:
trick flow
Lunati
