Can I use 95v6 parts tot repair my 95gt front end damage?
waynenorcross
Front side damage. See the pics. Great to hear the body panels are the same.
View attachment 15324View attachment 15325
What is wrong with the V6 doner car? Why not swap GT drivetrain into the V6 chassis/body? I personally wouldn't want to spend a lot of time rebuilding something that probably has a salvage title and might never drive straight again
Hans
Hans
Netherlands
Yeah that car took a hard hit. That's what I was getting at earlier. I'd like to see some more pics of the damage. Can we see the frame rails?
Is there another part creased in the back of the car?
IMG20210910151359.jpgIMG20210910151123.jpg?hash=00f1cd39b1228c49d0e98906c8b5e8ad.jpg Engine still running, radiator not leaking. Though the belts both snapped. The air pump is damaged.
badass98svt
Plastic parts and headlights are the least of your worries.
Hans
Hans
Netherlands
more than likely the core support would need to be replaced as well.
Had a good one cut of at the wrecking yard. Inner side panels cut at the spring perches still attached. And bought the fenders and hood.
Pallgor
I’m not sure if this type of damage is in your expertise. You look like you need a body shop. Some might be able to be pulled but you will definitely need a radiator support headlight mounting panel + more.
OR you can straighten it the way my buddy did his in high school with a fairl long very THICK chain and a really strong tree. He tied it around the tree and the frame and then got it going in reverse 5-10 mph before the chain caught it and yanked it out.
If you do this way please get it on video I almost peed myself watching my buddy do it 30 yrs ago. The car never really did drive straight, run right or fly nearly as well after that.... Just an overall loss of performance both on road and off/above it.
Pleasanton/Hayward, CA
Gregomatic
Heart of America/ KC,KS.
I did that with an AMC Jeep Eagle and it worked. Mostly. Not quite perfect, but much better than before.
I also Bought a Chevy Cavalier (4 door) for $200 that had been T boned by a van. Looked like someone died in it.
The support between the front and back door was also pushed in about 3" in the middle.
I took it to a HyVee parking lot because their light poles were secured to a 4' tall cement stanchion. Wrapped a cable come-along around both and started cranking.
Two doors off a donor car later and it was almost water tight.
Made a great beater/loaner car that was still going strong a few thousand miles later when I gave it to someone in need.
I don't quite see that happening with both of those rails though.
Hey Frank, how does a tube frame compare with rail frame as far as strength is concerned?
hazel113
