Car is running at 21 psi [fuel pressure]
Drentz
Pueblo, CO
Hey guys!
Vacuum lines are all done
New IAC
New cap rotor, wires, ignition coil, all other tune up items ect.
Car is still running like garbage. So I tested the fuel pressure... 21 +\- 2. Would this be a fuel pump problem or a ccrm problem?
Thanks guys!
95opal
As rz stated check with vac disconnected but pkugged, should see 39-40.
JFYI with vac connected you should see 30-35, so it appears you are a bit low.
RichV
CO
Ya, little low. I would start with the fpr before changing the fp. I have a stock one you can have if you come get it.
Drentz
Drentz
Pueblo, CO
Well thank you for the offer Rich! I just changed that last week. I'm running out of cheap things to fix....
95opal
You can never rule out a kinked hardline, might want to check that before taking the plunge on a new pump.
RichV
CO
Bummer. Do both HGs while in there.
May as well throw in a cam. What's an extra couple of hours. :D
Drentz
Drentz
Pueblo, CO
Exactly what I was thinking lol. This is more less an opportunity to do crazy fun things :)) my engine rebuild is now a necessity :) I was thinking maybe a crate engine? This one has 122xxx. And could be cracked. Thoughts?
Drentz
Drentz
Pueblo, CO
I'm not good at priorities, my brain is that of a goldfish.
Speed is my #1 priority. (Of course)
I'm super new at all this. So my motorlogical skills are pretty terrible.
So I guess for now I should just pull off the heads clean them. Make sure they are not warped. Clean them up. Perhaps like rich said throw in a new cam. Any suggestions would as always be awesome!
Also a big thank you to everyone! Hope when I learn a bit more I can help others in the way y'all have helped me!
It all depends on what your budget is? I have over 200,000 miles on my stock block and it's still going strong.
If you on a budget, pick up exploder GT40 heads and intake and a Steeda19, TFS stage 1 cam, or an FRPP E cam and you go from an measly 215 HP to about 300ish.
Drentz
Drentz
Pueblo, CO
I'll look into that cam. But aren't my cobra heads gt40 heads?
yes. Didn't know you had a cobra.
In that case, Keep the heads and intake. cam swap is up to you, The cams I listed are pretty mild and I doubt much of an improvement over the stock cobra.
Dws 95 mustang GT
