Car won't go in reverse???
BlackCobra50
I just tried to back my car out of the driveway and I couldn't get it to go in reverse at all. It goes into every other gear just fine, but it stops before I can get it into reverse. I just change the clutch cable recently. What could be the problem??
Thanks.
94 Sn-95GT
Clutch may not be releasing all the way.
Have you tried putting it in reverse with the car off and then starting it?
Reverse doesn't have syncros like the forward gears.
B
BlackCobra50
I've tried trying to put it in reverse with the car on, and the car off, it still doesn't go in.
94 Sn-95GT
Car off. Clutch in. Put it into like 4th then try to reverse.
Do you have an aftermarket shifter? Make sure the shift stops didn't come lose preventing you from putting it in reverse.
B
BlackCobra50
I've tried every combination to get it to go in. I have a B&M shifter, I dont know if thats the problem or not though. The shift stops have always been very tight so i dont think its that.
Addermk2
back your stops off a little bit, and try letting off the clutch gently while pulling it into reverse... should click in once everything lines up.
B
BlackCobra50
I'm gonna try to adjust the stops and everything, might get a STOCK shifter to see if that will fix it.
x182dan
try putting it in reverse and slowly releasing the clutch sometimes that helps
95Grandtouring5.0
Put the car in first gear, let the clutch out a little bit so the car moves forward a few inches. Then try and go for reverse.
foss_94gt
i do the same sometimes when she doesn't want to go in
Steven
SC
Step one: Open door
Step two: take car out of gear, and parking brake off
step three: Use foot to push back car
Congradulations Mr. Flinstone.
B
BlackCobra50
Steven said:
Step one: Open door
Yea... I don't want to do that everywhere I go lol. If I go to the store I'd have to find a spot where I could just pull straight out. lol Thanks for the advice tho lol
Steven
SC
LOL.. i've been there before. You eventually just go, oh F' it and push the car back. Your cable probably needs to be adjusted badly.
B
BlackCobra50
How do I adjust it?? I've never adjusted it before :dontknow:
Steven
SC
What kind of cable did you put in the car? Stock replacement, or a ford stock part.. or adjustable? I'd bet the junk aftermarket stock one stretched already, and if its a ford one, then you probably need to get it to readjust itself. If not get an adjustable one. Not getting into gear and clutch cables are two peas in a pod.
