joe65
- Joined
- Feb 4, 2020
- Messages
- 1,478
- Reaction score
- 1,444
Most likely. My mind would start there. But doesn't mean i'm smart...lol
Or, its a drag car only, no signals needed!
multifunction switch. I think you could test for voltage at the flasher to test it, or swap it out
https://www.americanmuscle.com/turn-signal-switch-9498.html?utm_content=Exterior - Windshield Components|OPR&T5_Var4=95741&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&utm_campaign=AMM+Mustang+Vehicle+Medium&T5_Var3=blue&intl=0&dialogtech=ppc&gclid=Cj0KCQjwkZiFBhD9ARIsAGxFX8C66Yfaz_cuaR_XFnQAsiasukNjgh7hBQFFfQA67GQWcN0WbnBOKWoaAnKdEALw_wcB&gclsrc=aw.ds
the alarm will not effect those lights. The are tied into the parking lights but would need to be a pretty bad screw up to effect the rest of the lighting.
I had a strange problem earlier this year that I ended up tracing back to the cruise control amplifier which in my 94 was down by the fuse box. Check where yours is and see if disconnecting the harness to it helps anything. On mine I discovered I was only getting 9v to the lights and it went away when the amp was disconnected.
according to that diagram the 3rd brake light is driven directly off the brake light switch and does not go through the multifunction switch. Test for power at the brake switch(on top of the pedal)I have no third brake light either… fuse 9 is good…
Also don't just go check individual fuses. It takes less time to actually pull/inspect each fuse than it does to go through the manual and this way we can be sure its not a fuse that has nothing listed with the problem at hand.
Your switch may not be bad, it’s just letting the little bit of current go through it and the lights are draining the circuit. Make sure to check all of your grounds. There are some at the trans tunnel, right side just under the radio. There are grounds down by the pcm, there are grounds up behind the headlights, and the big one going to the engine.
Diligence, insanity, not wanting to spend money on this when there are other things I need to do for the car... loli respect your diligence. good luck i hope this gets you there.
I am definitely learning a lot about wiring, as I have never messed with it before.
I’m sorry brother, I must have misunderstood. Yes, there is a short from the splice to that fuse. You could probably just run a new wire to the fuse from the supply and fix that. I don’t think I would replace that switch until you get power going to it the way it’s supposed to.Your post has me confused.
The voltage drops between the section of light green and red wire that was spliced for the alarm and the fuse (power source side of the fuse box), I measured 11.46V at the splice and each side of the fuse measures 3.34V. I measured some other fuses and they were around 12V, so I'm assuming Fuse 9 should also be around 12V. So that was one issue, that there appears to be a short between the splice and the fuse box.
The second issue is the switch. My understand of how to test it was that it should have power on the lower prong but not the upper prong at rest. Which it did (albeit low at 3.34V), the upper prong at rest was 0.01V. When you push down on the brake pedal the upper prong should now have power, but in my case it didn't, when pushed the upper prong remained at 0.01V. This is supposed to indicate a bad switch?
Thanks for the reply, all morning I was saying, I wonder if I could just disconnect the battery, unbolt the fuse panel and run a new wire from the splice to the fuse box to bypass whatever was going on... The switch was $12 so I'll just hold on to it, and if it's not needed I'll return it. Time to step up my soldering game, as it was rough last night lol.I’m sorry brother, I must have misunderstood. Yes, there is a short from the splice to that fuse. You could probably just run a new wire to the fuse from the supply and fix that. I don’t think I would replace that switch until you get power going to it the way it’s supposed to.
