MadStang
lol thanks Jason. I just cut all the wires, we're goot!
no cruise is trans speedo.
Lobe sir
my name is manuel loberer and i lobe lobe.
ok I am done with this post I guess since it has turned soooo gay. If you need me pm me.
i still vote speedo sensor. the engine has its own tach signal via pcm.
vss acts 2 parts. 1 for cruise and 1 for speedo. 1 can still give speed sensor. or it may even be wiring to and from your pcm since you had the shenanigans with the XL100. you can pull the square engine harness connector from rear passenger side firewall and check for resistance. i'll look it up on the 2000 TSM i have.
