With all due respect....
It's cool what you guys are putting together on the cheap. But when you say it's cheap, or dollar for dollar modding a Honda is cheaper is not really true. It may be FOR YOU, but not for the normal person. Obviously having fabrication skills and a boatload of freebies makes anything cheap. If you look at it from the common person's perspective, you have a garage with basic hand tools, access to junkyards and craigslist, and obviously the internet. How cheap and fast could that Honda really get? I mean there are not a whole lot of fast Hondas out here that I've seen.
If I took a budget of $3000, had to get the car + mods. I'd do a 5.0 Fox/SN with AOD, assuming they're both healthy for $1-2K, also probably with a couple mods already, I'll just assume headers and a O/R H. Used gears, 3:73/4:11 maybe $100 install myself. Used GT40 intake/heads, $500 with new gaskets, install myself. Probably get a set of 1.7RR, used from a SN Cobra $150ish. Cheap lower/upper rear control arms, possibly subframe connectors, $250ish, install myself. 255 fuel pump, new $100, install myself. Used wet nitrous kit, $400, jetted for about 200-250HP. So with a $1500 purchase, I'm exactly at $3000. Now I lighten the shit out it by removing anything I absolutely don't need, I bet 2600lbs is more than possible. I'd probably pop $150 to get it on the dyno and dial in the nitrous jets with a/f. And a used pair of road race/auto-x tires for free-$50 from a local racer.
Now I have $3K to build the Honda. Since the above recipe can be done by anyone on this forum, the Honda build must be as well. So where do I start?
