voidfinger
- Joined
- Dec 16, 2006
- Messages
- 3,880
- Reaction score
- 0
Well guys over my schools fall break i worked on my car the whole 4 days. I pulled the coplete front end off my car... "A arms, springs, shocks/struts, spindles, breaks, eveyrthing. Well i replaced my old eibachs with new ones and also installed a poly bushing kit on the car. Along with new ball joints and tie rod ends. O and i forgot to mention my Cobra Brakes WHOOO HOOOO. Man what a difference. The car is soooo stiff now. I'm talking crazy stiff. the ride quality is down a little but not as bad as the bad shocks and struts i had on there. The car stops like someone strapped a bunjie cord to my back and snapped me with it.
List of stuff i did.
New Eibach prokit for the 94-04 convertable.
Poly Bushing Kit on the front "A arm bushings, coil spring bushings upper lower front and back, off set rack bushing, probably more, just cant remember now lol"
New balljoints "with greese fittings"
New Tie rod ends "with greese fittings"
Kyb GR2 shocks and struts
Cobra brake set up "used cobra rotors and calipers, new carbon matalic pads, pieced together stainless steel brake lines." The lines were pieced together, cost about 95 dollars, which is cheap since the other ones you can buy cost like 150 lol.
I would highly recommend any of these things to people... I'm so happy with the way the car handles now, just want to replace my popping 160k steeda cc plates, and steering rag joint, and put the poly bushings into the upper and lower control arms and housing and i'm doooooonnnee.. Sweet handling
