Cobra Brake swap??
voidfinger
Hey guys, just curious but what all do i need to swap the brakes on my gt to cobra spec? thanks o and included is some pics of a set i'm buying ... thanks
[attachment deleted by admin]
V
voidfinger
will they bolt to the car like the gt brakes just like this or will i need more stuff... Are the hoses reusable? I've read that Conversion kits come with "brakets" but are the brakets the things thats attached to one caliper and on the other is is off a little bit??? thanks guys for whatever help you can give me... I'm not to brake savy. O0
Jrgunn5150
My kit came with brackets and hoses. The brackets run from the spindle to the caliper, to space it out from the hub to clear the bigger rotor. The hoses are a different thread.
V
voidfinger
so in that pic, it doesn't show the brackets rightr???? or is the brackets the things that the caliper is connected to in the photo? thanks
Jrgunn5150
The bracket it what the caliper sits in, you only need new hoses. And maybe some of that caliper paint Duplicolor makes O0 Oh yeah, the bolts might not work off your stock calipers, I also got new bolts, and sleeves.
V
voidfinger
Whats a sleeve??? I'm sorry if the questions seem dumb. thanks
Jrgunn5150
I think they call them pins also, the little sleeve the caliper bolts got through.
V
voidfinger
mmm, ok. So is there any noticable difference in stopping power over the 98 gt fronts? thanks
DropTopPony
South Jersey
big difference over the single piston we had stock!
you need
caliper/bracket combo
13" rotors
new lines (stainless would be good upgrade
banjo bolt for Cobra/Bullitt calipers.
and like said above get new retainer pins and washers...look in the haynes manual to see pics of them as they suggest new ones also.
V
voidfinger
can i get those at an auto parts store? just wondeing thanks. What would be good to clean these things up too? thanks guys
Jrgunn5150
They probably need to order Cobra parts, they do sell some pretty gnarly chemical stripper in parts stores, make usre it's safe for rubber though. Or you could always use oven cleaner and a wire brush/wheel.
scarface
Guest
you can buy a cobra brake hardware kit at napa for less than 20 bux a side. we had to find it when we did the brakes on wyotechMSA's car.
V
voidfinger
So they sell a kit at napa :) that means i can get the rotors turned and the kit at the same place. What does the kit come with ??? o and by the way, i just won the auction for $180. :banana:
Jrgunn5150
Congratulations dude! Your local NAPA turns rotor's? The ones out here just talk B.S. about how "these newer cars rotor's are only like .015 over spec to begin with". Even if that were true, I would only turn about .010 off them anyway, A holes.
scarface
Guest
Item#: UP 83014A
Price: $12.99
V
voidfinger
yea, that was my first job... i worked at napa in the machine shop. I did all kinda stuff.... like valve guides, valve jobs, resurfacing things...blocks,heads,flywheels, etc etc. Bore and hone blocks, did oil changes lol. Sand blasted , turned rotors....turned so many rotors.... Dude i did all kinda shit :) thats when the min wage was less than 5... and i get paid like 9 somthing now..... i would go back and work for 5 now.... i loved that job. :blah2:
