I'll be happy to drive this thing under a 1/2 tank..Mmmmmmmmmmmmmmmmmmmmmm fancy pancy
Sent from my SM-G930T using Tapatalk
Sent from my SM-G935V using Tapatalk
Let's go! In March?and go out to button willow?
Let's go! In March?
Thanks dude. Just going to ask if you needed a sumped 03-04 On3 tank...too late! You'll be more than happy with the Lethal hat and Glenns tanks. Are you going to run two pumps? Bravo with those cars man, not sure how you do it, taking care of one is enough work!Like the tank/fuel mods.
I also just ordered the Glenn's cobra tank and Division X return fuel setup for my Mach 1.
No, not yet. I need to get it on a drive-on lift, check the DS angle at both ends. Just by eyeballing it, it looks like it's at zero or parallel to the floorboard. I belive it needs -3 to -4.5?I get a driver vibration at 100ish, but I believe it is to do with driveline angle. Have you compared the shaft angle at the back of the trans to the differential?
Sent from my XT1254 using Tapatalk
From what I've read, they have to be opposite of each other. Like if the engine is -3°, the diff has to be +3°. But that is just a memory bank grab.No, not yet. I need to get it on a drive-on lift, check the DS angle at both ends. Just by eyeballing it, it looks like it's at zero or parallel to the floorboard. I belive it needs -3 to -4.5?
Thanks Thomas! Doesn't make a whole lotta sense, but maybe the flange yoke is offset? Anyway turned it 90* and on the street it seems to make a difference. Still need to test it on the highway. Still going to check my driveshaft angle.Rotate you driveshaft 90* on the pinion flange (assuming the pinion angle is correct) to get rid/diagnose the driveline vibration.
Yes sir, it's about the same cost wise to build an SRA and an IRS, not necessarily a drag car. Plus if you can't beat em, join them!IRS?????????? I dont think they are that much better than a built SRA. You did extremely good! Tires will make a huge difference in handling. It will feel like a whole different car
