Coyote Swap P0122 and P0223
96gt226410
Gen. 2 Coyote swap using control pack. Got P0122 and P0223 codes for my TPS. Anyone have any ideas? Might try to swap the throttle body with a known good one out of a 2015 F150. Thanks.
96gt226410
96gt226410
The throttle body is good. I guess I have another wiring issue. This might be my second wiring problem with this control pack. Anyone have this issue before?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Sorry I can’t help with this, I didn’t use the control pack. But I seem to remember reading that the control pack requires a specific part number throttle pedal? Does this ring a bell?
96gt226410
96gt226410
I used the new Ford Accelerator Pedal that came with the control pack.
madijorian
Did you ever figure it out, I'm in the exact same position with a gen 2 control pack in a 2003? Mine will start and run but not very well and dies within a minute
lwarrior1016
South Mississippi
Man, I ran in to this same damn problem on my swap. I bought a brand new throttle body, brand new pedal, double checked all my wiring.
Turned out, I had a bad computer.
madijorian
I bought a new throttle body, a new pedal, and tested the wires from the throttle body to the computer.
Then went out on a limb and tried a computer. The computer fixed it.
Were you getting no throttle response and unable to idle when you were getting the codes?
lwarrior1016
South Mississippi
It still idled but there was no throttle response. When the code popped, the throttle would go dead until I cycled the key.
The idle did get pretty rough when it coded though.
HollisC75
