custom gauges need help
91MARO95STANG
Hey guys well my gauges crapped out the other day and i just ordered a new cluster bezel to get a new look in my car. so to the point i need ur help once again :rolleyes:
ok i ordered this cluster bezel:
GAUGE POD, INSTRUMENT CLUSTER BEZEL 1994-2004
the sizes are:
4 are 2x 1/16 ( FUEL LEVEL, WATER TEMP, VOLTS, & OIL)
2 are 3x 3/8 (MPH & RPMs)
and the actual gauges im getting are AUTO/METER, but dont know witch to get just yet cuz it asks me
For Fuel:
Whats the sender Ohm Range?
( 0hms empty, 90 ohms full)
(240 ohms empty, 33 ohms full)
(73 ohms empty, 10 ohms full)
(0 ohms empty, 30 ohms full)
(16 ohms empty, 158 ohms full)
Oil:
is it oil temp or oilt pressure?
so far i got these on wish list :
MPH
http://www.summitracing.com/parts/ATM-4493/
RPM
http://www.summitracing.com/parts/ATM-4497/
OIL PRESS
http://www.summitracing.com/parts/ATM-4327/
WATER TEMP
http://www.summitracing.com/parts/ATM-4337/
VOLTS
http://www.summitracing.com/parts/ATM-4391/
FUEL is the one I?m still having problems to get.
So plz help me out guys thanks.
Gtnut1996
that is the exact set up i am doing. i have been debating on ordering really soon but i just done heads and intake. i got to tune it now
JB_SN95
i did a quick search and im pretty sure youd need the "16 ohms empty, 158 ohms full" fuel gauge. according to some info i got off another forum 15ohms is empty and 160ohms is full
# Set the Instrument Gauge System Tester to 160 ohms.
# Key in ON position.
# Turn the ignition switch to RUN for one second.
# Key in OFF position.
# Set Instrument Gauge System Tester to 15 ohms. The fuel gauge should read E or below when carrying out this test step.
# Wait one minute and read the fuel gauge.
# Set Instrument Gauge System Tester to 160 ohms. The fuel gauge should read F (full) or above when carrying out this test step.
