On 3 Performance said:
What going to "fail" is the fact that if you cut the springs and you do it half assed or cut them wrong (EVEN WITH A NON-PROGESSIVE SPRING) they will not be the same, and if one spring is softer or stiffer than the others or your ride height out of wack your car will not handle correctly and depending on how off they are even in a drag race you are headed for problems. Suspension plays a large part in going down the track even in a straight line. I am not going to defend my opinion any further you seem to have no problem with doing things that way and more power to you. I for one think its a stupid thing to do for reasons I have already explained.
but your only "reasons" are "its not right".
like i said, a CUT spring is IDENTICAL to a STIFFER and shorter spring. cutting them DOES NOT make them weaker. the spring rates will change, but if both springs are cut the SAME amount they rate will change the same amount.
basically you'd have to be one dumb SOB to mess up cutting some coil springs, and while in some peoples opinions its not a good idea, in some situations its actually ALOT better idea. you realize some of the ford racing performance parts come with instructions to cut the rear springs to tailor ride height.....
also, the "hondas" you see riding around bouncing all over are doing so because they either HEATED the springs making them much softer, or the struts (actually coilover shocks on most honda/acuras) are completely trashed and cant handle the increased spring rate, OR they are sitting on the bumpstops.
i dont really care that you work for a "shop" or "company" your opinion is not FACT, trying to pass them off as fact just makes you look bad. everything i have posted is MY opinion backed up by facts, or examples..
