Addermk2
- Joined
- Mar 7, 2006
- Messages
- 2,534
- Reaction score
- 55
prove me wrong
sry but i dont have the time or patience to actually do a test. if you just think bout it, u can understand the logic without actually having to see it done. idk how else to prove it?Addermk2 said:prove me wrong
Addermk2 said:I dont see your logic at all. The way you are looking at it is... the spring will compress the same amount, no matter what size it is.
which is wrong. if a 10" 250lb/in spring compresses 1", and half of that spring compresses 1" under the same weight... What did the other half of the spring do while they were one piece?
Bottom line... you are wrong
a306juGRnot said:Addermk2 said:I dont see your logic at all. The way you are looking at it is... the spring will compress the same amount, no matter what size it is.
i understand how you are thinking...yes half of the spring did compress .5inch while it was 10inch long. but the spring is no longer 10 in long. is it 5 inch long now and that is how you would look at it and or measure it. if you put 250 lbs on the new spring, it will still go down 1 inch.
