damage to my car..
98Viperblue
I started earing a rubbing noise, where I hit the curb... Seems the damage is worse than I tought..
:sad5:
Just watch.. And tell me how bad it is..
http://s98.photobucket.com/albums/l249/mikelovespaige/?action=view&current=DSCF9004.flv
The rim..
Magic
Some time zone
Bent axle.
Those the Kumho Ecsta SPT on those gold 00 R wheels? What happened? Rain?
Anyhow, you need to replace the axle shaft.
duff daddy
Time for either hardened 28 splines from Moser or your can swap 31 spline with a termi diff
98Viperblue
Although I really can't afford to upgrade, I guess its the only way to go..
Can you guys help me out? Like links and stuff to what I need to get exactly to fix this.
:sad5:
duff daddy
http://www.summitracing.com/parts/MSR-A882852/
If people tell you you need 31 spline axles, dont listen, you can get them but these 28's you will not break. They are about 30% stronger over stock then then oe axles and you will not need to change your carrier. After you buy these go to ford and get new axle bearings (side bearings, get new axle seals and some new c clips, and some new juice for the rear end and youll be good to go. Also with the new axle on just slide your rotor on hold it in place with a lug nut and let the axle spin and see if the rotor got damaged as well.
Magic
Some time zone
Agreed.
However, your other option(s) should the $$ funds not allow for them at the moment or you could care less about putting a drag slick or drag radial on the car or a combination of both, then you can just buy a single axle from any Driveline shop (pick up your favorite Mustang magazine and give one of the advertisers a call), for under $100 each.
OR Find someone who already has upgraded their axles and is selling their stock ones. Might get lucky and score the pair for $50?
OR if you can't find a set of used axles from a 94-98 8.8, the axles from the V6 7.5 94-98 cars are the same thing = direct fit. (The 94-98 7.5 and 8.8 axle shaft length is 29 15/16 inches).
As Duff mentioned, good time to get new axle bearings and seals.
Passenger
I smacked a curb in my '95 a few years ago. Did similar dmg.
Along with the wheel, it also snapped my brake rotor, and bent the flange on the axle shaft. They're EXTREMELY simple to replace. New axles are around $75 new from your local Advanced Auto store.
sleepn_sn95
Indy
Same thing happened to me... except my axle completely snapped clean off and my car was sitting on top of my wheel. Luckily axles are not that expensive if you just get a stock replacement.
