Dead spot in gauges
Late4Work
I dunno why this is the way it is, put my gauges in and took a pic..... Anyone else have this problem????
Antcjr
Warner Robins, GA
Pull everything back out. The bulb in the middle is either out or not installed properly. Are those the white face gauges from brothersperformance?
there's 5 and he has 2 out. oil pressure is out too.
you should replace all of them. if you don't, in a month another one will go out.
Late4Work
Late4Work
LEDs r in there, and I could have sworn I fixed it, ughhhh I'll try it again
Late4Work
Late4Work
And as far as the gauges, they came with the cobra when I bought it
pull the bulb out, spin it 180 degrees and push it back in. Leds are polarized meaning they have to be put in a certain way unlike the standard halogen bulbs.
Redford
SC
I have this problem for the top of my speedometer and tachometer, but not nearly as pronounced... it's just dimmer than the rest of it. I use halogens because my LEDs burned out & didn't give light as well. Looks like you just need to replace them.
dang. what a pain to fix. lol. have to pull all that out again. ug..... test it before you fully re-assemble it. lol.
Late4Work
Late4Work
I did, and the odd part is, when I fixed those two, one of the ones on the left went bad, so I had to spin it, but the gauges r fixed and lookin good
